system ha interconnect port sharing show
Display the high-availability interconnect device port sharing information
The system ha interconnect port sharing show command displays the high-availability interconnect device port sharing status information.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
Use this parameter to display all the fields for each node.
[-node <nodename>]- Node (privilege: advanced)-
Use this parameter to display information from the specified node in the cluster.
[-enabled {true|false}]- Enabled (privilege: advanced)-
Selects the nodes that match this parameter value.
The following example displays the HA interconnect device port sharing information:
cluster1::*> system ha interconnect port sharing show Node Enabled -------------- ------- node1 true node2 false
