ONTAP commands
system ha interconnect port sharing show
Display the high-availability interconnect device port sharing information
The system ha interconnect port sharing show command displays the high-availability interconnect device port sharing status information.
[-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] (privilege: advanced) }
Use this parameter to display all the fields for each node.
[-node <nodename>] - Node (privilege: advanced)
Use this parameter to display information from the specified node in the cluster.
[-enabled {true|false}] - Enabled (privilege: advanced)
Selects the nodes that match this parameter value.
The following example displays the HA interconnect device port sharing information:
cluster1::*> system ha interconnect port sharing show
Node            Enabled
node1           true
node2           false
