snaplock event-retention policy create
Create SnapLock Event Based Retention policies for a Vserver
The snaplock event-retention policy create
command is used to create Event Based Retention (EBR) policies for a Vserver. A policy consists of a policy-name
and a retention-period
. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
-vserver <vserver name>
- Vserver Name-
Specifies the name of the Vserver for which a policy needs to be created.
-name <text>
- Policy Name-
Specifies the name of the EBR policy to be created.
-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}
- Event Retention Period-
Specifies the retention period for an EBR policy.
The following example creates a new EBR policy "p1" for Vserver "vs1" with a retention period of "10 years"
vs1::> snaplock event-retention policy create -name p1 -retention-period "10 years"
