lun bind show
Show list of Vvol bindings
Shows the configured VVol to protocol endpoint bindings.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)
Selects the bindings that match this parameter value.
- [-protocol-endpoint-msid <integer>]- PE MSID (privilege: advanced)
- [-protocol-endpoint-vdisk-id <text>]- PE Vdisk ID (privilege: advanced)
- [-vvol-msid <integer>]- VVol MSID (privilege: advanced)
- [-vvol-vdisk-id <text>]- VVol Vdisk ID (privilege: advanced)
- [-vserver-uuid <UUID>]- Vserver UUID (privilege: advanced)
- [-protocol-endpoint-path <path>]- Protocol Endpoint (privilege: advanced)
Selects the bindings that match this parameter value. Examples of correct LUN paths are /vol/vol1/lun1and/vol/vol1/qtree1/lun1.
- [-protocol-endpoint-node <nodename>]- PE Node (privilege: advanced)
- [-vvol-path <path>]- VVol (privilege: advanced)
- [-vvol-node <nodename>]- VVol Node (privilege: advanced)
- [-secondary-lun <Hex 64bit Integer>]- Secondary LUN (privilege: advanced)
- [-is-optimal {true|false}]- Optimal binding (privilege: advanced)
- [-reference-count <integer>]- Reference Count (privilege: advanced)
cluster1::*> lun bind show -vserver vs1
Vserver        Protocol Endpoint                  Node
                   Vvol LUN                            Secondary LUN Optimal?
vs1            /vol/VV1/PE1                      cluster-node1
                   /vol/VV2/30dfab                      d20000010000 false
                   /vol/VV3/234ace                      d20000020000 true
                   /vol/VV3/234acf                      d20000030000 true
               /vol/VV2/PE2                      cluster-node2
                   /vol/VV2/30dfab                      d20000010000 true
4 entries were displayed.
The example above displays all the LUN bindings on Vserver vs1.
 PDFs
PDFs
