ONTAP commands
lun bind show
Show list of Vvol bindings
Shows the configured VVol to protocol endpoint bindings.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-vserver <Vserver Name>] - Vserver Name (privilege: advanced)
Selects the bindings that match this parameter value.
[-protocol-endpoint-msid <integer>] - PE MSID (privilege: advanced)
[-protocol-endpoint-vdisk-id <text>] - PE Vdisk ID (privilege: advanced)
[-vvol-msid <integer>] - VVol MSID (privilege: advanced)
[-vvol-vdisk-id <text>] - VVol Vdisk ID (privilege: advanced)
[-vserver-uuid <UUID>] - Vserver UUID (privilege: advanced)
[-protocol-endpoint-path <path>] - Protocol Endpoint (privilege: advanced)
Selects the bindings that match this parameter value. Examples of correct LUN paths: /vol/vol1/lun1 and /vol/vol1/qtree1/lun1
[-protocol-endpoint-node <nodename>] - PE Node (privilege: advanced)
[-vvol-path <path>] - VVol (privilege: advanced)
[-vvol-node <nodename>] - VVol Node (privilege: advanced)
[-secondary-lun <Hex 64bit Integer>] - Secondary LUN (privilege: advanced)
[-is-optimal {true|false}] - Optimal binding (privilege: advanced)
[-reference-count <integer>] - Reference Count (privilege: advanced)
cluster1::*> lun bind show -vserver vs1
Vserver        Protocol Endpoint                  Node
                   Vvol LUN                            Secondary LUN Optimal?
vs1            /vol/VV1/PE1                      cluster-node1
                   /vol/VV2/30dfab                      d20000010000 false
                   /vol/VV3/234ace                      d20000020000 true
                   /vol/VV3/234acf                      d20000030000 true
               /vol/VV2/PE2                      cluster-node2
                   /vol/VV2/30dfab                      d20000010000 true
4 entries were displayed.
The example above displays all the LUN bindings on Vserver vs1.
