network interface capacity show
Display the number of IP data LIFs capable of being configured on the cluster.
The network interface capacity show
command displays the number of IP LIFs of role data
supported on the cluster, as well as the number of IP LIFs of role data
currently configured on the cluster.
The number of IP LIFs of role data that are supported on a node depends on the hardware platform and the Cluster's Data ONTAP version. If one or more nodes in the cluster cannot support additional LIFs, then none of the nodes in the cluster can support additional LIFs.
The following displays the IP data LIF capacity.
cluster1::> network interface capacity show IP Data LIF IP Data LIF Supported Limit Count ----------------- --------------- 1024 256
