metrocluster check run
Check the MetroCluster setup
The metrocluster check run
command performs checks on the MetroCluster configuration and reports configuration errors if any.
To run this command, at least one DR group needs to be configured. The command checks the following parts of the configuration:
Node Configuration:
node-reachable: This check verifies that the node is reachable.
metrocluster-ready: This check verifies that the node is ready for MetroCluster configuration.
local-ha-partner: This check verifies that the HA partner node is in the same cluster.
ha-mirroring-on: This check verifies that HA mirroring for the node is configured.
symmetric-ha-relationship: This check verifies that the relationship between the node and its HA partner is symmetric.
remote-dr-partner: This check verifies that the DR partner node is in the remote cluster.
dr-mirroring-on: This check verifies that DR mirroring for the node is configured.
symmetric-dr-relationship: This check verifies that the relationship between the node and its DR partner is symmetric.
remote-dr-auxiliary-partner: This check verifies that the DR auxiliary partner node is in the remote cluster.
symmetric-dr-auxiliary-relationship: This check verifies that the relationship between the node and its DR auxiliary partner is symmetric.
storage-failover-enabled: This check verifies that storage failover is enabled.
has-intercluster-lif: This check verifies that the node has an intercluster LIF.
node-object-limit: This check verifies that the node object limit option for the node is turned on.
Aggregate Configuration:
mirroring-status: This check verifies that the aggregate is mirrored.
disk-pool-allocation: This check verifies that the disks belonging to this aggregate have been correctly allocated to the right pools.
At the end of the check the command displays a summary of the results. This summary output can be viewed again by running metrocluster check show . If any of the rows in this output show any warnings more details can be viewed by running the metrocluster check show command for that component.
[-skip-dr-simulation {true|false}]
- Skip the DR Readiness Checks (privilege: advanced)-
If this optional parameter is set to true, the switchover and switchback simulations are not run.
The following example shows the execution of the command when there are no warnings:
clusA::> metrocluster check run Last Checked On: 4/9/2014 20:11:46 Component Result ------------------- --------- nodes ok clusters ok lifs ok config-replication ok aggregates ok 5 entries were displayed. Command completed. Use the "metrocluster check show -instance" command or sub-commands in "metrocluster check" directory for detailed results.
The following example shows the execution of the command when there are some warnings:
clusA::> metrocluster check run Last Checked On: 4/9/2014 20:11:46 Component Result ------------------- --------- nodes warning clusters ok lifs ok config-replication ok aggregates ok 5 entries were displayed. Command completed. Use the "metrocluster check show -instance" command or sub-commands in "metrocluster check" directory for detailed results.
