security anti-ransomware volume pause
Pause anti-ransomware on a volume
The security anti-ransomware volume pause
command pauses Anti-ransomware monitoring on a volume.
-vserver <vserver name>
- Vserver Name-
Anti-ransomware monitoring is paused in the evaluation mode on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>
- Volume Name-
Anti-ransomware monitoring is paused on volumes matching the parameter value.
