storage port reset
Reset a storage port
The storage port reset
command resets a specified storage port. This command is not supported on Ethernet storage ports (type = ENET).
-node {<nodename>|local}
- Node (privilege: advanced)-
Use this parameter to specify the node on which the port resides.
-port <text>
- Port (privilege: advanced)-
Use this parameter to specify the port that needs to be reset.
The following example resets port 0a on node node1:
cluster1::> storage port reset -node node1 -port 0a
