network ndp prefix delete-all
Delete IPv6 prefixes on a given IPspace
The network ndp prefix delete-all
command deletes all prefixes learned from the specified IPspace.
-ipspace <IPspace>
- IPspace Name (privilege: advanced)-
Use this parameter to specify the IPspace where the IPv6 prefixes are to be deleted.
The following example deletes all IPv6 prefixes within IPspace ips1.
cluster1::*> network ndp prefix delete-all -ipspace ips1
