vserver export-policy config-checker rule show
Show error entries for rules in export policy configuration checker job
The vserver export-policy config-checker rule show
command displays information about error related to configuration in export policy rules. If a rule has any issues the configuration checker job will log information about such errors on the node where the job runs. The command displays the following information:
Node name
Vserver name
Export policy name
Export policy rule index number
Export policy rule error
[-fields <fieldname>,…]
If you specify the
-fields
parameter, the command only displays the fields that you specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all entries. [-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays detailed error information for node that matches the specified value.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays detailed error information for Vservers that match the specified value.
[-policy <export policy name>]
- Policy Name-
If you specify this parameter, the command displays detailed error information for policy that match the specified value.
[-rule-index <integer>]
- Rule Index-
If you specify this parameter, the command displays detailed error information for rule-index that match the specified value.
[-error <text>]
- Error Details-
If you specify this parameter, the command displays rule index information for error that match the specified value. The complete error string needs to be specified within "{}".
The following example displays information about error related to export rules:
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test (vserver export-policy config-checker rule show) Rule Node Vserver Policy Index Error ---------- ------------ --------- --------- ---------------------------------- node-vsim3 vs34 test 1 DNS lookup for host "h1" failed vs34 test 2 Entry not found for "UserName: testuser", DNS lookup for host "h2" failed 2 entries were displayed.
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test -rule-index 1 (vserver export-policy config-checker rule show) Node: node-vsim3 Vserver: vs34 Policy Name: test Rule Index: 1 Error Details: DNS lookup for host "h1" failed
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test -error {DNS lookup for host "h1" failed} (vserver export-policy config-checker rule show) Rule Node Vserver Policy Index Error ---------- ------------ --------- --------- ---------------------------------- node-vsim3 vs34 test 1 DNS lookup for host "h1" failed
