vserver fpolicy show-passthrough-read-connection
Display connection status for FPolicy passthrough-read
The vserver fpolicy show-passthrough-read-connection
command displays the status of the passthrough-read connection from all FPolicy servers. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. If you do not specify any parameters, the command displays following information about the passthrough-read connection from FPolicy servers:
Vserver name
FPolicy policy name
Node name
FPolicy server IP address
Passthrough-read connection status
You can specify the -fields
parameter to specify which fields of information to display. In addition to the fields above, you can display the following fields.
Session ID of the control channel
Time passthrough-read channel was connected
Time passthrough-read channel was disconnected
Reason for passthrough-read channel disconnection
You can specify the -instance
parameter to display information for all passthrough-read connections in the list form.
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
[-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays information only about the passthrough-read connections on the specified node.
[-vserver <Vserver Name>]
- Vserver-
If you specify this parameter, the command displays information only about the passthrough-read connections for the specified Vserver.
[-policy-name <Policy name>]
- Policy-
If you specify this parameter, the command displays information only about the passthrough-read connections that are attached with the specified FPolicy policy.
[-server <IP Address>]
- Server-
If you specify this parameter, the command displays information only about the passthrough-read connections from the specified FPolicy server.
[-control-session-id <text>]
- Session ID of the Control Channel-
If you specify this parameter, the command displays information only about the passthrough-read connections that are connected with the specified control session ID. The passthrough-read connection is attached to a control connection that has a unique control session ID.
[-server-status <Status of fpolicy passthrough-read connection>]
- Server Status-
If you specify this parameter, the command displays information only about the passthrough-read connections that have the specified status.
[-connected-since <MM/DD/YYYY HH:MM:SS>]
- Time Channel Was Connected-
If you specify this parameter, the command displays information only about the passthrough-read connections that have the specified connection time.
[-disconnected-since <MM/DD/YYYY HH:MM:SS>]
- Time Channel Was Disconnected-
If you specify this parameter, the command displays information only about the passthrough-read connections that have the specified disconnection time.
[-disconnect-reason <Reason for fpolicy passthrough-read disconnection>]
- Reason for Disconnection-
If you specify this parameter, the command displays information only about the passthrough-read connections that are disconnected because of the specified disconnect reason.
This example displays information about passthrough-read connections from all FPolicy servers.
cluster1::> vserver fpolicy show-passthrough-read-connection FPolicy Server Vserver Policy Name Node Server Status --------------- ------------- ------------ ----------------- -------------- vs2.example.com pol_cifs_2 FPolicy-01 2.2.2.2 disconnected vs1.example.com pol_cifs_1 FPolicy-01 1.1.1.1 connected 2 entries were displayed.
This example displays information about passthrough-read connections from all connected FPolicy servers.
cluster1::> vserver fpolicy show-passthrough-read-connection -server-status connected FPolicy Server Vserver Policy Name Node Server Status --------------- ------------- ------------ ----------------- -------------- vs1.example.com pol_cifs_1 FPolicy-01 1.1.1.1 connected
This example displays information about passthrough-read connections from FPolicy servers configured in an FPolicy policy.
cluster1::> vserver fpolicy show-passthrough-read-connection -policy-name pol_cifs_1 -instance Node: FPolicy-01 Vserver: vserver_1.example.com Policy: pol_cifs_1 Server: 2.2.2.2 Session ID of the Control Channel: 8cef052e-2502-11e3-88d4-123478563412 Server Status: connected Time Passthrough Read Channel was Connected: 9/24/2013 10:17:45 Time Passthrough Read Channel was Disconnected: - Reason for Passthrough Read Channel Disconnection: none
