network tuning icmp show
Show ICMP tuning options
This command displays the current state of the ICMP tuning options for the given node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
Displays all ICMP tuning options.
[-node {<nodename>|local}]
- Node-
Specifies the node for which the ICMP tuning options are displayed.
[-is-drop-redirect-enabled {true|false}]
- Drop redirect ICMP-
Displays all entries that match the "is-drop-redirect-enabled" value.
[-tx-icmp-limit <integer>]
- Maximum number of ICMP packets sent per second-
Displays all entries that match the "tx-icmp-limit" value.
[-redirect-timeout <integer>]
- Maximum seconds for route redirect timeout-
Displays all the entries that match the "redirect-timeout" value.
cluster1::> network tuning icmp show Drop Redirect Maximum ICMP Redirect Timeout Node ICMP Sends per Second in Seconds --------- ------------- ---------------- ---------------- node1 true 100 300
