ONTAP 9.9.1 commands
network tuning icmp show
Show ICMP tuning options
This command displays the current state of the ICMP tuning options for the given node.
{ [-fields <fieldname>,…​]
| [-instance ] }
Displays all ICMP tuning options.
[-node {<nodename>|local}] - Node
Specifies the node for which the ICMP tuning options are displayed.
[-is-drop-redirect-enabled {true|false}] - Drop redirect ICMP
Displays all entries that match the "is-drop-redirect-enabled" value.
[-tx-icmp-limit <integer>] - Maximum number of ICMP packets sent per second
Displays all entries that match the "tx-icmp-limit" value.
[-redirect-timeout <integer>] - Maximum seconds for route redirect timeout
Displays all the entries that match the "redirect-timeout" value.
cluster1::> network tuning icmp show
Drop Redirect Maximum ICMP      Redirect Timeout
Node      ICMP          Sends per Second  in Seconds
node1
          true          100               300
