ONTAP commands
system node virtual-machine disk-object-store show
Display the list of object store configurations
The system node virtual-machine disk-object-store show command displays the list of object store containers that contain each node's disks.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - ONTAP Node Name (privilege: advanced)
Represents the name of the ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-object-store-name <object store name>] - ONTAP Name for this Object Store Config (privilege: advanced)
Selects object store configurations with the specified name.
[-server <text>] - Fully Qualified Domain Name of the Object Store Server (privilege: advanced)
Selects containers on the specified server.
[-port <integer>] - Port Number of the Object Store (privilege: advanced)
Selects containers attached on the specified port.
[-container-name <text>] - Container Name (privilege: advanced)
Selects containers with the specified name.
[-azure-account <text>] - Azure Storage Account (privilege: advanced)
Selects containers in the specified Azure storage account.
[-alive {true|false}] - Is Server Alive (privilege: advanced)
Selects containers based on their aliveness state, as seen from the ONTAP node.
The following example displays the list of containers for each node in the cluster.
cluster1::*> system node virtual-machine disk-object-store show
                  Object Store
     Node         Name         Azure Storage Account   Container Name   Alive
     node1
                  objstore1    storageaccount1         container1        true
     node2
     2 entries were displayed.
