system node virtual-machine disk-object-store show
Display the list of object store configurations
The system node virtual-machine disk-object-store show command displays the list of object store containers that contain each node's disks.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node <nodename>]- ONTAP Node Name (privilege: advanced)
Represents the name of the ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
- [-object-store-name <object store name>]- ONTAP Name for this Object Store Config (privilege: advanced)
Selects object store configurations with the specified name.
- [-server <text>]- Fully Qualified Domain Name of the Object Store Server (privilege: advanced)
Selects containers on the specified server.
- [-port <integer>]- Port Number of the Object Store (privilege: advanced)
Selects containers attached on the specified port.
- [-container-name <text>]- Container Name (privilege: advanced)
Selects containers with the specified name.
- [-azure-account <text>]- Azure Storage Account (privilege: advanced)
Selects containers in the specified Azure storage account.
- [-alive {true|false}]- Is Server Alive (privilege: advanced)
Selects containers based on their aliveness state, as seen from the ONTAP node.
The following example displays the list of containers for each node in the cluster.
cluster1::*> system node virtual-machine disk-object-store show
                  Object Store
     Node         Name         Azure Storage Account   Container Name   Alive
     node1
                  objstore1    storageaccount1         container1        true
     node2
     2 entries were displayed.
 PDFs
PDFs
