storage aggregate efficiency show
Display aggregate storage efficiency details
The storage aggregate efficiency show
command displays information about the different storage efficiency of all the aggregates.If no parameters are specified, the command displays the following information for all aggregates:
Aggregate
Node
Cross-vol-background-dedupe State (Enabled, Disabled)
Cross-vol-inline-dedupe State (Enabled, Disabled)
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-aggregate <aggregate name>]
- Aggregate-
Displays the aggregate name. If this parameter is specified, the command displays detailed information about the storage efficiency of the specified aggregate.
[-node {<nodename>|local}]
- Node-
Displays the node which owns the aggregate. If this parameter is specified, the command displays storage efficiency information only about the aggregates that are located on the specified node.
[-cross-volume-background-dedupe {true|false}]
- Cross Volume Background Deduplication-
Displays whether the cross volume background deduplication is enabled/disabled in the aggregate.
[-cross-volume-inline-dedupe {true|false}]
- Cross Volume Inline Deduplication-
Displays whether the cross volume inline deduplication is enabled/disabled in the aggregate.
[-cross-volume-dedupe-savings {true|false}]
- Has Cross Volume Deduplication Savings-
Displays whether the aggregate may have savings from cross volume deduplication.
[-auto-adaptive-compression-savings {true|false}]
- Has Auto Adaptive Compression Savings-
Displays whether the aggregate may have auto adaptive compression savings.
The following example displays information about all aggregates that are owned by nodes in the local cluster:
cluster:::> storage aggregate efficiency show Aggregate: aggr0 Node: vivek6-vsim2 Has Cross Volume Deduplication Savings: false Cross Volume Background Deduplication: false Cross Volume Inline Deduplication: false Aggregate: aggr1 Node: vivek6-vsim2 Has Cross Volume Deduplication Savings: true Cross Volume Background Deduplication: true Cross Volume Inline Deduplication: true 2 entries were displayed.
