storage failover mailbox-disk show
Display information about storage failover mailbox disks
The storage failover mailbox-disk show
command lists the mailbox disks that are used by storage failover. The command displays the following information:
Node name
Whether the mailbox disk is owned by the local node or by its partner
Disk name
Disk universal unique identifier (UUID)
This command is available only at the advanced privilege level and higher.
[-fields <fieldname>,…]
If -fields <fieldname>,… is used, the command displays only the specified fields.
[-instance ]
If this parameter is used, the command displays detailed information about all entries.
[-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects the mailbox disks that are associated with the specified node.
[-location {local|partner|tertiary}]
- Mailbox Owner (privilege: advanced)-
Selects the mailbox disks that have the specified relationship to the node.
[-diskindex <integer>]
- Mailbox Disk Index (privilege: advanced)-
Selects the mailbox disk that has the specified index number.
[-diskname <text>]
- Mailbox Disk Name (privilege: advanced)-
Selects the mailbox disks that match the specified disk name.
[-diskuuid <text>]
- Mailbox Disk UUID (privilege: advanced)-
Selects the mailbox disks that match the specified UUID.
[-physical-location {local|partner|mediator}]
- Mailbox Disk Physical Location (privilege: advanced)-
Selects the mailbox disks that match the specified physical location.
[-location-id <nvramid>]
- System ID of the Node where the Disk is Attached (privilege: advanced)-
Selects the mailbox disks that match the specified location-id.
[-location-name <text>]
- Mailbox Disk Location (privilege: advanced)-
Selects the mailbox disks that match the specified location-name.
The following example displays information about the mailbox disks on a node named node1:
cluster1::*> storage failover mailbox-disk show -node node1 Node Location Index Disk Name Physical Location Disk UUID ------- --------- ----- ------------- ------------------ -------------------- node1 local 0 1.0.4 local 20000000:8777E9D6:[...] local 1 1.0.6 partner 20000000:8777E9DE:[...] partner 0 1.0.1 local 20000000:877BA634:[...] partner 1 1.0.2 partner 20000000:8777C1F2:[...]
