network interface service-policy clone
Clone an existing network service policy
The network interface service-policy clone
command creates a new service policy that includes the same services and allowed addresses as an existing policy. Once the new service policy has been created, it can be modified as necessary without impacting the original policy.
-vserver <vserver name>
- Vserver (privilege: advanced)-
Use this parameter to specify the name of the Vserver of the service policy to be cloned.
-policy <text>
- Policy Name (privilege: advanced)-
Use this parameter to specify the name of the service policy to be cloned.
-target-vserver <vserver name>
- Vserver Name (privilege: advanced)-
Use this parameter to specify the name of the vserver on which the new service policy should be created.
-target-policy <text>
- New Service Policy Name (privilege: advanced)-
Use this parameter to specify the name of the new service policy.
The following example shows the cloning of a service policy.
cluster1::> network interface service-policy show -vserver cluster1,ipspace1 Vserver Policy Service: Allowed Addresses --------- -------------------------- ---------------------------------------- cluster1 custom1 intercluster-core: 0.0.0.0/0 management-core: 0.0.0.0/0 management-ssh: 0.0.0.0/0 default-intercluster intercluster-core: 0.0.0.0/0 management-https: 0.0.0.0/0 default-management management-core: 0.0.0.0/0 management-autosupport: 0.0.0.0/0 management-ssh: 0.0.0.0/0 management-https: 0.0.0.0/0 default-route-announce management-bgp: 0.0.0.0/0 ipspace1 default-intercluster intercluster-core: 0.0.0.0/0 management-https: 0.0.0.0/0 default-management management-core: 0.0.0.0/0 management-autosupport: 0.0.0.0/0 management-ssh: 0.0.0.0/0 management-https: 0.0.0.0/0 default-route-announce management-bgp: 0.0.0.0/0 7 entries were displayed. cluster1::> network interface service-policy clone -vserver cluster1 -policy custom1 -target-vserver ipspace1 -target-policy custom2 cluster1::> network interface service-policy show -vserver cluster1,ipspace1 Vserver Policy Service: Allowed Addresses --------- -------------------------- ---------------------------------------- cluster1 custom1 intercluster-core: 0.0.0.0/0 management-core: 0.0.0.0/0 management-ssh: 0.0.0.0/0 default-intercluster intercluster-core: 0.0.0.0/0 management-https: 0.0.0.0/0 default-management management-core: 0.0.0.0/0 management-autosupport: 0.0.0.0/0 management-ssh: 0.0.0.0/0 management-https: 0.0.0.0/0 default-route-announce management-bgp: 0.0.0.0/0 ipspace1 custom2 intercluster-core: 0.0.0.0/0 management-core: 0.0.0.0/0 management-ssh: 0.0.0.0/0 default-intercluster intercluster-core: 0.0.0.0/0 management-https: 0.0.0.0/0 default-management management-core: 0.0.0.0/0 management-autosupport: 0.0.0.0/0 management-ssh: 0.0.0.0/0 management-https: 0.0.0.0/0 default-route-announce management-bgp: 0.0.0.0/0 8 entries were displayed.
