security oauth2 show
Display global OAuth 2.0 configuration
The security oauth2 show
command displays the status of the OAuth 2.0 feature.
The following example displays the OAuth 2.0 feature status information -
cluster1::> security oauth2 show Is OAuth 2.0 Enabled: true
