system node hardware unified-connect modify
Modify the Fibre Channel and converged networking adapter configuration
The system node hardware unified-connect modify
command changes the adapter configuration. Any changes to the adapter mode or type will require a reboot for the changes to take effect. The adapter must also be offline before you can make any changes.
The adapter argument is in the form Xy where X is an integer and y is a letter. For example: 4a
For a target adapter, use the network fcp adapter modify command to bring the adapter offline.
For an initiator adapter, use the system node run local storage disable adapter
command to take the adapter offline.
The -mode
parameter refers to the mode of the adapter and can be either fc
or cna
The -type
parameter refers to the FC-4 type of the adapter and can be initiator
, target
, or fcvi
The -force
parameter suppresses confirmation prompts.
The adapter type fcvi is supported only on platforms with FCVI adapters.
-node {<nodename>|local}
- Node-
Specifies the node of the adapter.
-adapter <text>
- Adapter-
Specifies the adapter.
[-m, -mode {fc|cna}]
- Configured Mode-
Specifies the mode.
[-t, -type {initiator|target|fcvi}]
- Configured Type-
Specifies the FC-4 type.
[-f, -force <true>]
- Force-
Suppresses warnings and confirmation prompts.
cluster1::> system node hardware unified-connect modify -node node1 -adapter 0d -mode cna
Configures the mode of adapter 0d on node1 to CNA.
