vserver export-policy cache flush
Flush the Export Caches
The vserver export-policy cache flush
command clears out the contents of the export policy caches for a Vserver. You might need to flush the caches to allow the changes to immediately take effect for your NFS clients because of:
A change to your export policy rules.
Modifying a host name record in a name server (i.e., local hosts or DNS).
Modifying a PTR record in a DNS server (i.e., reverse DNS lookup).
Modifying the entries in a netgroup in a name server (i.e., local netgroup, LDAP, or NIS).
Recovering from a network outage that resulted in a netgroup being partially expanded.
To flush the caches, you must specify the following items:
Vserver: either a specific Vserver or use "*" to flush all of them.
You can optionally specify the following items:
Node: if flushing the
access
cache, you can also specify which node to flush it on. -
Cache to flush: by default all but
showmount
will be flushed.
Note that the showmount
cache is not used to determine NFS client access and as such is only flushable explicitly.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver on which you want to flush the caches.
[-node <nodename>]
- Node-
This parameter specifies the node on which you want to flush the
access
cache. [-cache {all|access|host|id|name|netgroup|showmount|ip}]
- Cache Name-
This parameter specifies the name of the cache which you want to flush. Possible values include the following:
all
- All caches butshowmount
. This is the default. -
access
- The export-policy rules access cache. -
host
- The host name to IP cache. -
id
- The ID to credential cache. -
ip
- The IP to host name cache. -
name
- The name to ID cache. -
netgroup
- The netgroup cache. -
showmount
- The showmount caches.
The following example flushes the access cache on a Vserver named vs0:
cluster1::> vserver export-policy cache flush -vserver vs0 -cache access
