vserver export-policy cache flush
Flush the Export Caches
The vserver export-policy cache flush command clears out the contents of the export policy caches for a Vserver. You might need to flush the caches to allow the changes to immediately take effect for your NFS clients because of:
A change to your export policy rules.
Modifying a host name record in a name server (i.e., local hosts or DNS).
Modifying a PTR record in a DNS server (i.e., reverse DNS lookup).
Modifying the entries in a netgroup in a name server (i.e., local netgroup, LDAP, or NIS).
Recovering from a network outage that resulted in a netgroup being partially expanded.
To flush the caches, you must specify the following items:
Vserver: either a specific Vserver or use "*" to flush all of them.
You can optionally specify the following items:
Node: if flushing the accesscache, you can also specify which node to flush it on.
Cache to flush: by default all but showmountwill be flushed.
Note that the showmount cache is not used to determine NFS client access and as such is only flushable explicitly.
- -vserver <vserver name>- Vserver
This parameter specifies the name of the Vserver on which you want to flush the caches.
- [-node <nodename>]- Node
This parameter specifies the node on which you want to flush the accesscache.
- [-cache {all|access|host|id|name|netgroup|showmount|ip}]- Cache Name
This parameter specifies the name of the cache which you want to flush. Possible values include the following: -
all- All caches butshowmount. This is the default.
access- The export-policy rules access cache.
host- The host name to IP cache.
id- The ID to credential cache.
ip- The IP to host name cache.
name- The name to ID cache.
netgroup- The netgroup cache.
showmount- The showmount caches.
The following example flushes the access cache on a Vserver named vs0:
cluster1::> vserver export-policy cache flush -vserver vs0 -cache access
 PDFs
PDFs
