security dynamic-authorization trust-score-component show
Display trust score components
The security dynamic-authorization trust-score-component show displays information about the components that comprise the trust score.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays all the fields for the specified dynamic authorization trust score components.
[-vserver <vserver name>]- Vserver-
Selects the dynamic authorization trust score components that match this parameter value.
[-component <text>]- Component Name-
[-weight <integer>]- Score Weight-
[-max-percent-score-weight <double hundredths>]- Max Percentage Score Weight-
[-provider-uri {scheme://(hostname|IPv4 Address|'['IPv6 Address']')…}]- Trust Score Provider URI of Component-
[-max-score <integer>]- Max Trust Score of Component-
[-min-score <integer>]- Min Trust Score of Component-
[-score-field <text>]- Score field to check in JSON response-
[-score-type {trust-score|risk-score}]- Score Type-
This parameter specifies if the score returned from the components is trust score or risk score. The trust score is in ascending order with a higher score denoting a higher trust level, while the risk score is in descending order. The default value is
trust-score. [-provider-http-headers <text>,…]- Provider HTTP headers-
The example below displays information about all dynamic authorization trust score components, both built-in and custom:
cluster1::> security dynamic-authorization trust-score-component create -component comp1 -weight 20 -max-score 100 -provider-uri https://provider.example.com/trust-scores/users/admin1/component1.json -score-field score cluster1::> security dynamic-authorization trust-score-component show Percentage Vserver Component Name Score Weight Score Weight --------------- ------------------------------ ------------ ------------ cluster1 authentication_history_policy 20 33.33 cluster1 comp1 20 33.33 cluster1 trusted_device 20 33.33 svm0 authentication_history_policy 20 50.00 svm0 trusted_device 20 50.00 5 entries were displayed.
The following command displays the details of all components matching the name comp1 :
cluster1::> security dynamic-authorization trust-score-component show -vserver cluster1 -component comp1 -instance
Vserver: cluster1
Trust Score Component Name: comp1
Weight of the Component: 20
Max Percentage Weight of the component: 50.00
Trust Score Provider URI of Component: https://provider.example.com/trust-scores/users/admin1/component1.json
Max Score of Component: 100
Score field to check in JSON response: score
Provider HTTP headers: -
