security certificate truststore load
Load the default root certificates to truststore
The security certificate truststore load command installs default root certificates in the certificate table of type 'server-ca'. These are the certificates required to validate any incoming server certificate during the SSL handshake process. Note: This command only installs PEM formatted certificates.
- { [-path <text>]- File to load PEM certificates from (privilege: advanced)
This specifies the path to the PEM formatted certificate bundle. This optional parameter can have an empty value (the default).
- | [-uri <text>]- URL to download PEM certificates from (privilege: advanced) }
This specifies the URL from which to download the PEM formatted certificate bundle.
- [-ontap-version <ontap_version>]- Certificates from specific ONTAP version (privilege: advanced)
This specifies the ONTAP version in which the certificates were introduced. Only those certificates will be loaded. This optional parameter can have an empty value (the default) which indicates that no filtering on version is done.
The following example installs the default certificate bundle:
cluster1::> security certificate truststore load
 PDFs
PDFs
