vserver restamp-msid
Restamp the MSIDs of all the volumes in a Vserver to match or be different from the source Vserver
The vserver restamp-msid
command restamps MSIDs of all volumes in a dp-destination Vserver to make them either identical to the VserverDR source Vserver. The command is run on secondary VserverDR site and automatically updates the MSID preserve behavior for the Vserver. A snapmirror resync must be run after this command completes.
-vserver <vserver name>
- Vserver name (privilege: advanced)-
The name of the dp-destination Vserver.
-preserve-msid {true|false}
- Make MSID same as that of source Vserver. False sets the values as different. (privilege: advanced)-
Boolean value through which the user can specify whether to make the MSIDs of the volumes same as that of Source Vserver. Specifying true will make the MSIDs same and specifying false will make them different.
This example will stamp all the volumes of Vserver vs1dp with the same MSID as the source Vserver.
cluster1::>vserver restamp-msid -vserver vs1dp -preserve-msid true
