network port broadcast-domain show
Display layer 2 broadcast domain information
Display broadcast domain information.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-ipspace <IPspace>]
- IPspace Name-
Selects the broadcast domains that match the IPspace name.
[-broadcast-domain <Broadcast Domain>]
- Layer 2 Broadcast Domain-
Selects the broadcast domains that match the broadcast domain name.
[-mtu <integer>]
- Configured MTU-
Selects the broadcast domains that match the MTU value. This field is the MTU that was configured by the user, which might be different from the operational MTU.
[-ports [node>:<port],…]
- Ports-
Selects the broadcast domains that contain the network ports. For example, node1:e0a will display broadcast domains that contain node1:e0a network port.
[-port-update-status {complete|in-progress|error|overridden-while-offline}]
- Port Update Status-
Selects the broadcast domains that contain the network port status. For example, specifying "error" will display broadcast domains that contain "Error" network port status.
[-port-update-status-details <text>,…]
- Status Detail Description-
Selects the broadcast domains that contain the network port status detail text.
[-port-update-status-combined {complete|in-progress|error|overridden-while-offline}]
- Combined Port Update Status-
Selects the broadcast domains that contain the combined network port status. For example, specifying "error" will display broadcast domains that contain a combined network port status of "Error".
[-failover-groups <failover-group>,…]
- Failover Groups-
Selects the broadcast domains that contain the failover groups.
[-subnet-names <subnet name>,…]
- Subnet Names-
Selects the broadcast domains that contain the subnet name or names.
[-is-vip {true|false}]
- Is VIP Broadcast Domain-
Selects the broadcast domains that match a specific "is-vip" flag. Specifying "true" matches only broadcast domains associated with the Virtual IP feature; "false" matches only broadcast domains that do not.
The following example displays general information about broadcast domains.
cluster1::> network port broadcast-domain show IPspace Broadcast Update Name Domain Name MTU Port List Status Details ------- ----------- ------ ----------------------------- -------------- Cluster Cluster 9000 node1:e0a complete node1:e0b complete Default Default 1500 node1:e0c complete node1:e0d complete 2 entries were displayed.
