vserver cifs group-policy central-access-policy show-defined
Show applicable central access policies defined in the Active Directory
The vserver cifs group-policy central-access-policy show-defined
command displays information about the central access policies that are defined in the Active Directory. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS servers:
Vserver name
Name of the central access policy
SID
Creation time
Modification time
Member rules
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only for central access policies for the specified Vserver.
[-name <TextNoCase>]
- Name-
If you specify this parameter, the command displays information only for central access policies that match the specified name.
[-sid <windows sid>]
- Identifier-
If you specify this parameter, the command displays information only for central access policies that match the specified SID.
[-description <text>]
- Description-
If you specify this parameter, the command displays information only for central access policies that match the specified description.
[-ctime <Date>]
- Creation Time-
If you specify this parameter, the command displays information only for central access policies that match the specified creation time.
[-mtime <Date>]
- Modification Time-
If you specify this parameter, the command displays information only for central access policies that match the specified modification time.
[-rules <TextNoCase>,…]
- Central Access Rules-
If you specify this parameter, the command displays information only for central access policies that match the specified member rules.
The following example displays information for all central access policies:
cluster1::> vserver cifs group-policy central-access-policy show-defined Vserver Name SID ---------- -------------------- ----------------------------------------------- vs1 p1 S-1-17-3386172923-1132988875-3044489393-3993546205 Description: policy #1 Creation Time: Tue Oct 22 09:34:13 2013 Modification Time: Wed Oct 23 08:59:15 2013 Member Rules: r1 vs1 p2 S-1-17-1885229282-1100162114-134354072-822349040 Description: policy #2 Creation Time: Tue Oct 22 10:28:20 2013 Modification Time: Thu Oct 31 10:25:32 2013 Member Rules: r1 r2 2 entries were displayed.
