ONTAP commands
vserver cifs group-policy central-access-policy show-defined
Show applicable central access policies defined in the Active Directory
The vserver cifs group-policy central-access-policy show-defined command displays information about the central access policies that are defined in the Active Directory. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS servers:
  • Vserver name
  • Name of the central access policy
  • SID
  • Description
  • Creation time
  • Modification time
  • Member rules
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>, …​ parameter, the command only displays the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only for central access policies for the specified Vserver.
[-name <TextNoCase>] - Name
If you specify this parameter, the command displays information only for central access policies that match the specified name.
[-sid <windows sid>] - Identifier
If you specify this parameter, the command displays information only for central access policies that match the specified SID.
[-description <text>] - Description
If you specify this parameter, the command displays information only for central access policies that match the specified description.
[-ctime <Date>] - Creation Time
If you specify this parameter, the command displays information only for central access policies that match the specified creation time.
[-mtime <Date>] - Modification Time
If you specify this parameter, the command displays information only for central access policies that match the specified modification time.
[-rules <TextNoCase>,…​] - Central Access Rules
If you specify this parameter, the command displays information only for central access policies that match the specified member rules.
The following example displays information for all central access policies:
cluster1::> vserver cifs group-policy central-access-policy show-defined
Vserver    Name                 SID
vs1        p1                   S-1-17-3386172923-1132988875-3044489393-3993546205
        Description: policy #1
      Creation Time: Tue Oct 22 09:34:13 2013
  Modification Time: Wed Oct 23 08:59:15 2013
       Member Rules: r1
vs1        p2                   S-1-17-1885229282-1100162114-134354072-822349040
        Description: policy #2
      Creation Time: Tue Oct 22 10:28:20 2013
  Modification Time: Thu Oct 31 10:25:32 2013
       Member Rules: r1
                     r2
2 entries were displayed.
