ONTAP commands
system services ndmp on
(DEPRECATED)-Enable NDMP service
Note This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "vserver services ndmp on " command.
The system services ndmp on command is used to enable the NDMP service across any node in the cluster.
-node {<nodename>|local} - Node
The specific node on which the NDMP service is to be enabled.
The following example is used to turn on the NDMP service on node named node1:
cluster1::> system services ndmp on -node node1
