      vserver migrate abort
Abort a Vserver migrate operation
This command aborts a Vserver migrate operation. It is normally run on the destination cluster of the migrate operation. If the destination cluster cannot be accessed, the abort command can be run on the source cluster to cleanup the migrate operation on the source cluster. The migrate operation must be in migrate-paused, or in a failed migrate status, to be aborted.
- -vserver <vserver name>- Vserver Name
Name of the Vserver to be aborted.
cluster1::> vserver migrate abort -vserver test
 PDFs
PDFs
