vserver audit prepare-to-downgrade
Restore the Audit configuration to Earlier Release of Data ONTAP
The vserver audit prepare-to-downgrade
command restores the Audit configurations for ONTAP based on the input parameter disable-feature-set.
-disable-feature-set <downgrade version>
- Data ONTAP Version (privilege: advanced)-
This parameter specifies the ONTAP version that introduced the new Audit features and needs to be removed. The value can be one of the following:
9.0.0 - Disables the Audit features introduced in the ONTAP release 9.0.0. The following events are removed from the
event
list: -
File share event. The corresponding parameter value is
file-share
Audit policy change event. The corresponding parameter value is
audit-policy-change
Local user account management event. The corresponding parameter value is
user-account
Local security group management event. The corresponding parameter value is
security-group
Authorization policy change event. The corresponding parameter value is
authorization-policy-change
cluster1::*> vserver audit prepare-to-downgrade -disable-feature-set 9.0.0
