vserver cifs domain name-mapping-search show
Display the list of trusted domains for name-mapping searches
The vserver cifs domain name-mapping-search show command displays information about trusted domains of the home domain by Vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver
This parameter specifies the name of the Vserver for which you want to display information about the trusted domains.
- [-trusted-domains <domain name>,…]- Trusted domains
This parameter specifies a comma-delimited list of fully qualified domain names of trusted domains for which you want to display information.
The following example displays information about all preferred trusted domains:
cluster1::> vserver cifs domain name-mapping-search show Vserver Trusted Domains -------------- ---------------------------------- vserver_1 CIFS1.EXAMPLE.COM
 PDFs
PDFs
