lun import create
Create an import relationship
This command creates an import relationship between a specified LUN and a specified foreign disk so you can import the foreign disk data into a LUN.
The foreign disk must be marked as foreign using storage disk set-foreign-lun command before you can begin the import progress.
The LUN must be of the same size as the foreign disk.
-vserver <Vserver Name>
- Vserver Name (privilege: advanced)-
Specifies the Vserver that contains the LUN where you import data to from the foreign disk data.
-foreign-disk <text>
- Foreign Disk Serial Number (privilege: advanced)-
Specifies the serial number of the Foreign Disk.
-path <path>
- LUN Path (privilege: advanced)-
Specifies the path of the LUN where you want to import the data of the foreign disk to. Examples of correct LUN paths are
/vol/vol1/lun1
and/vol/vol1/qtree1/lun1
cluster1::> lun import create -vserver vs1 -path /vol/dvol1/lun1 -foreign-disk 6000B5D0006A0000006A020E00040000
Creates an import relationship between lun1 at the path /vol/dvol1/lun1 and foreign disk with serial number 6000B5D0006A0000006A020E00040000.
