job show-bynode
Display a list of jobs by node
The job show-bynode
command displays information about jobs on a per-node basis. The command output depends on the parameters specified with the command. If no parameters are specified, the command displays information about all jobs in the cluster that are currently owned by a node.
To display detailed information about a specific job, run the command with the -id
parameter. The detailed view includes all of the default information plus additional items.
You can specify additional parameters to display only information that matches the values you specify for those parameters. For example, to display information only about jobs running on a specific node, run the command with the -node
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Use this parameter to display information only about the jobs that are associated with the node you specify.
[-id <integer>]
- Job ID-
Use this parameter to display information only about the jobs that match the ID or range of IDs you specify.
[-vserver <vserver name>]
- Owning Vserver-
Use this parameter with the name of a Vserver to display only jobs that are owned by that Vserver.
[-name <text>]
- Name-
Use this parameter to display information only about the jobs that match the job name you specify.
[-description <text>]
- Description-
Use this parameter to display information only about the jobs that match the description you specify.
[-affinity {Cluster|Node}]
- Affinity-
Use this parameter with an affinity value to display only jobs that match the affinity you specify.
[-username <text>]
- User Name-
Use this parameter with a username to display only jobs that are associated with that user.
The following example displays information about all jobs on a per-node basis:
node::> job show-bynode Owning Node Job ID Name Vserver Affinity -------------- ------ --------------- ---------- -------- node0 1501 log-rotation node-vserver Cluster Descr:logrotation job node1 1498 log-rotation node-vserver Cluster Descr:logrotation job node2 1499 log-rotation node-vserver Cluster Descr:logrotation job node3 1500 log-rotation node-vserver Cluster Descr:logrotation job
