job show-bynode
Display a list of jobs by node
The job show-bynode command displays information about jobs on a per-node basis. The command output depends on the parameters specified with the command. If no parameters are specified, the command displays information about all jobs in the cluster that are currently owned by a node.
To display detailed information about a specific job, run the command with the -id parameter. The detailed view includes all of the default information plus additional items.
You can specify additional parameters to display only information that matches the values you specify for those parameters. For example, to display information only about jobs running on a specific node, run the command with the -node parameter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to display information only about the jobs that are associated with the node you specify.
 [-id <integer>]- Job ID-
Use this parameter to display information only about the jobs that match the ID or range of IDs you specify.
 [-vserver <vserver name>]- Owning Vserver-
Use this parameter with the name of a Vserver to display only jobs that are owned by that Vserver.
 [-name <text>]- Name-
Use this parameter to display information only about the jobs that match the job name you specify.
 [-description <text>]- Description-
Use this parameter to display information only about the jobs that match the description you specify.
 [-affinity {Cluster|Node}]- Affinity-
Use this parameter with an affinity value to display only jobs that match the affinity you specify.
 [-username <text>]- User Name-
Use this parameter with a username to display only jobs that are associated with that user.
The following example displays information about all jobs on a per-node basis:
node::> job show-bynode
                                      Owning
Node           Job ID Name            Vserver    Affinity
node0          1501   log-rotation    node-vserver
                                                 Cluster
               Descr:logrotation job
node1          1498   log-rotation    node-vserver
                                                 Cluster
node2          1499   log-rotation    node-vserver
                                                 Cluster
node3          1500   log-rotation    node-vserver
                                                 Cluster
