system bridge add
Add a bridge for monitoring
The system bridge add command enables you to add FC-to-SAS bridges for in-band monitoring in a MetroCluster configuration.
-name <text>- Bridge Name-
This parameter identifies the bridge being added for in-band monitoring.
The following command adds a bridge with name ATTO_FibreBridge7600N_1 for monitoring:
cluster1::> system bridge add -name ATTO_FibreBridge7600N_1
cluster1::> stor br show
Symbolic Is Monitor Managed
Bridge Name Monitored Status By Vendor Model Bridge WWN
ATTO_2000001086a183c0 bridge1
true ok in-band Atto FibreBridge 7600N 2000001086a183c0
ATTO_FibreBridge7600N_2 -
false - none Atto - 2000001086a18340
ATTO_FibreBridge7600N_3 -
false - none Atto - 2000001086a1ee40
ATTO_FibreBridge7600N_4 -
false - none Atto - 2000001086700a30
4 entries were displayed.
cluster1::>
