vserver vscan on-access-policy paths-to-exclude show
Display list of paths to exclude
The vserver vscan on-access-policy paths-to-exclude show
command displays the list of paths that are excluded from scanning belonging to the Vserver. If you do not specify any parameters, the command displays the following information about all on-access policies:
Vserver name
Policy name
List of Paths to exclude
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the policy names for the specified Vserver.
[-policy-name <Policy name>]
- Policy-
If you specify this parameter, the command displays information only about the specified policy name.
[-paths-to-exclude <File path>,…]
- File Paths Not to Scan-
If you specify this parameter, the command displays information only about the policies that have the specified paths that are excluded from scanning.
The following example displays the list of paths that are excluded from scanning for all the policies:
cluster1::> vserver vscan on-access-policy paths-to-exclude show Vserver Policy Name Paths Excluded --------------- ----------------- -------------------------------------------- cluster1 default_CIFS \test\test1 vs1 default_CIFS \test\test1 vs1 policy1 \test\test2,\test\test3 vs1 policy3 \test\test4 vs2 default_CIFS \test\test1 vs2 policy2 \test\test5 6 entries were displayed.
