ONTAP commands
cluster controller-replacement network displaced-interface restore-home-node
Restore home node for networked interfaces displaced by controller-replacement
Restore the original home node of logical interfaces that were displaced to another node due to a controller- replacement. A LIF that has been displaced to another node has had its home-node modified to another node because no network ports were available in the same broadcast domain on the original home-node. Restoring the home-node attempts to find a home-port on the original home node if a suitable port exists.
-node <nodename> - Node
Selects the node from which the LIF was displaced.
-vserver <vserver> - Vserver
Selects the vserver on which the LIF resides.
-lif-name <text> - Lif Name
Selects the name of the displaced LIF to be restored.
The following example restores the home-node of a displaced LIF.
cluster1::> cluster controller-replacement network displaced-interface restore-home-node -vserver vs0 -lif lif1
