job history show
Display a history of jobs
The job history show
command displays a history of completed jobs with newer entries displayed first. You can specify optional parameters to select information about job history items that match only those parameters. For example, to display information about jobs that were completed on February 27 at noon, run the command with -endtime "02/27 12:00:00"
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the completed jobs that match this parameter value.
[-record <Sequence Number>]
- Record ID-
Selects the completed jobs that match the record ID or range of record IDs you specify. Note that record IDs are unique for each node, not for the cluster as a whole. As a result, there can be two records with the same record ID within the cluster.
[-vserver <vserver name>]
- Owning Vserver-
Selects the completed jobs that are owned by the Vserver you specify.
[-id <integer>]
- Job ID-
[-endtime <MM/DD HH:MM:SS>]
- End Time-
Selects jobs that completed at the time you specify. This parameter is most useful when used with a range of times.
[-starttime <MM/DD HH:MM:SS>]
- Start Time-
Selects completed jobs that were started at the time you specify. This parameter is most useful when used with a range of times.
[-name <text>]
- Name-
[-description <text>]
- Description-
[-code <integer>]
- Status Code-
Selects the completed jobs that match this parameter value. Each job defines its own status codes. The completion text is more informative, but support technicians may request this numeric code.
[-progress <text>]
- Progress String-
[-completion <text>]
- Completion String-
[-jobuuid <UUID>]
- Job UUID (privilege: advanced)-
[-event-type {Idle|Running|Succeeded|Failed|Paused|Stopped|Deleted|Error}]
- Event Type-
[-event-time <MM/DD HH:MM:SS>]
- Event Time-
Selects the completed jobs that match this parameter value. This parameter is most useful when used with a range of times.
[-error-code <integer>]
- Job Manager Error Code-
[-error-text <text>]
- Job Manager Error Text-
[-username <text>]
- User Name-
The following example displays information about all completed jobs:
cluster1::> job history show Owning Time Node Vserver Name Event Job ID -------------- -------------- ---------- -------------------- --------- ------ 08/23 08:58:24 node1 node1-vs Vol Create Succeeded 76 Description: Create testvol Completion: Successful 08/23 08:58:22 node1 node1-vs Vol Create Running 76 Description: Create testvol 08/22 08:16:36 node1 node1-vs CLUSTER BACKUP AUTO weekly Succeeded 4 Description: Cluster Backup Job 08/22 08:15:49 node1 node1-vs CLUSTER BACKUP AUTO weekly Running 4 Description: Cluster Backup Job 08/22 08:15:08 node1 node1-vs CLUSTER BACKUP AUTO weekly Idle 4 Description: Cluster Backup Job 08/22 08:15:03 node1 node1-vs CLUSTER BACKUP AUTO weekly Running 4 Description: Cluster Backup Job 6 entries were displayed.
The following example shows how to use a range with the "endtime" parameter to select only the events that ended between 8:15 and 8:16 on August 22nd.
cluster1::> job history show -endtime "08/22 08:15:00".."08/22 08:16:00" Owning Time Node Vserver Name Event Job ID -------------- -------------- ---------- -------------------- --------- ------ 08/22 08:15:49 node1 node1-vs CLUSTER BACKUP AUTO weekly Running 4 Description: Cluster Backup Job 08/22 08:15:08 node1 node1-vs CLUSTER BACKUP AUTO weekly Idle 4 Description: Cluster Backup Job 08/22 08:15:03 node1 node1-vs CLUSTER BACKUP AUTO weekly Running 4 Description: Cluster Backup Job 3 entries were displayed.
