ONTAP commands
job history show
Display a history of jobs
The job history show command displays a history of completed jobs with newer entries displayed first. You can specify optional parameters to select information about job history items that match only those parameters. For example, to display information about jobs that were completed on February 27 at noon, run the command with -endtime "02/27 12:00:00" .
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the completed jobs that match this parameter value.
[-record <Sequence Number>] - Record ID
Selects the completed jobs that match the record ID or range of record IDs you specify. Note that record IDs are unique for each node, not for the cluster as a whole. As a result, there can be two records with the same record ID within the cluster.
[-vserver <vserver name>] - Owning Vserver
Selects the completed jobs that are owned by the Vserver you specify.
[-id <integer>] - Job ID
[-endtime <MM/DD HH:MM:SS>] - End Time
Selects jobs that completed at the time you specify. This parameter is most useful when used with a range of times.
[-starttime <MM/DD HH:MM:SS>] - Start Time
Selects completed jobs that were started at the time you specify. This parameter is most useful when used with a range of times.
[-name <text>] - Name
[-description <text>] - Description
[-code <integer>] - Status Code
Selects the completed jobs that match this parameter value. Each job defines its own status codes. The completion text is more informative, but support technicians may request this numeric code.
[-progress <text>] - Progress String
[-completion <text>] - Completion String
[-jobuuid <UUID>] - Job UUID (privilege: advanced)
[-event-type {Idle|Running|Succeeded|Failed|Paused|Stopped|Deleted|Error}] - Event Type
[-event-time <MM/DD HH:MM:SS>] - Event Time
Selects the completed jobs that match this parameter value. This parameter is most useful when used with a range of times.
[-error-code <integer>] - Job Manager Error Code
[-error-text <text>] - Job Manager Error Text
[-username <text>] - User Name
The following example displays information about all completed jobs:
cluster1::> job history show
                              Owning
Time           Node           Vserver    Name                 Event     Job ID
08/23 08:58:24 node1          node1-vs   Vol Create           Succeeded     76
     Description: Create testvol
      Completion: Successful
08/23 08:58:22 node1          node1-vs   Vol Create           Running       76
08/22 08:16:36 node1          node1-vs   CLUSTER BACKUP AUTO weekly
                                                              Succeeded      4
     Description: Cluster Backup Job
08/22 08:15:49 node1          node1-vs   CLUSTER BACKUP AUTO weekly
                                                              Running        4
08/22 08:15:08 node1          node1-vs   CLUSTER BACKUP AUTO weekly
                                                              Idle           4
08/22 08:15:03 node1          node1-vs   CLUSTER BACKUP AUTO weekly
                                                              Running        4
6 entries were displayed.
The following example shows how to use a range with the "endtime" parameter to select only the events that ended between 8:15 and 8:16 on August 22nd.
cluster1::> job history show -endtime "08/22 08:15:00".."08/22 08:16:00"
                              Owning
                                                              Running        4
                                                              Idle           4
                                                              Running        4
3 entries were displayed.
