storage aggregate plex offline
Offline a plex
The storage aggregate plex offline
command takes the specified plex offline. The aggregate specified with the -aggregate
parameter must be a mirrored aggregate and both plexes must be online. Prior to taking a plex offline, the system will flush all internally-buffered data associated with the plex and create a snapshot that is written out to both plexes. The snapshot allows for efficient resynchronization when the plex is subsequently brought back online.
-aggregate <aggregate name>
- Aggregate-
Name of an existing aggregate which contains the plex specified with the
-plex
parameter. -plex <text>
- Plex-
Name of a plex which belongs to the aggregate specified with the
-aggregate
parameter.
The following example takes plex0 of aggregate aggr1 offline:
cluster1::> storage aggregate plex offline -aggregate aggr1 -plex plex0
