vserver cifs users-and-groups local-user show-membership
Display local users' membership information
The vserver cifs users-and-groups local-user show-membership
command displays the membership of local users.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If this parameter is specified, the command displays local user membership information for local users that are associated with the specified Vserver.
[-user-name <CIFS name>]
- User Name-
If this parameter is specified, the command displays local user membership information for a local user that matches the specified user name.
[-membership <CIFS name>,…]
- Local Group That This User is a Member of-
If this parameter is specified, the command displays local user membership information for the local group of which this local user is a member.
The following example displays the membership information of all local users; user "CIFS_SERVER\Administrator" is a member of "BUILTIN\Administrators" group, and "CIFS_SERVER\u1" is a member of "CIFS_SERVER\g1" group.
cluster1::> vserver cifs users-and-groups local-user show-membership Vserver User Name Membership -------------- ------------------------------- ------------------------ vs1 CIFS_SERVER\Administrator BUILTIN\Administrators CIFS_SERVER\u1 CIFS_SERVER\g1 2 entries were displayed.
