storage automated-working-set-analyzer start
Command to start Automated Working Set Analyzer on node or aggregate
The automated-working-set-analyzer start command enables the Automated Workload Analyzer that is capable of doing the following:
Flash Pool modeling for an aggregate
Flash Cache modeling for a node - can not specify an aggregate.
Working set size estimation
Workload monitoring
-node <nodename>
- Node Name (privilege: advanced)-
This parameter indicates the node name that the AWA instance runs on.
[-flash-cache {true|false}]
- Flash Cache Node-wide Modeling (privilege: advanced)-
This parameter indicates whether the AWA is modeling flash-cache.
[-aggregate <aggregate name>]
- Aggregate (privilege: advanced)-
This parameter indicates the aggregate name that the AWA instance runs on.
[-working-set-size {true|false}]
- Working Set Size (privilege: advanced)-
This parameter indicates whether the AWA instance is configured to find the working set size.
cluster1::> storage automated-working-set-analyzer start -node vsim1 -aggregate aggr0
