template parameter show
Display template parameters
The template parameter show
command displays information about the parameters of a template. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all the parameters of all the templates in the system:
Name of the template
Name of the parameter
Permission (
readonly
orreadwrite
Default Value for the parameter
Readonly
To display detailed information about a single parameter of the template run the command with the -name
parameter. The detailed view provides all of the information in the previous list with the following additional information:
Recommended Value for the parameter
Maximum Length
Range Maximum
Range Minimum
Allowed Values
To display detailed information about all the parameters of the template, run the command with the -instance
parameter
You can specify additional parameters to display information that matches only those parameters. For example, to display information about all the parameters of the templates with readonly permissions, run the command with the -permission readonly
parameter.
[-fields <fieldname>,…]
This parameter specifies the fields that need to be displayed.
[-instance ]
If this parameter is specified, the command displays information about all entries.
[-template <template name>]
- Name of the template-
Name of the template.
[-name <text>]
- Name of the parameter-
If this parameter is specified, the command displays information about the parameter of all the templates that matches the specified parameter name.
[-permission <text>]
- Template permission-
If this parameter is specified, the command displays information about the parameter or parameters of all the templates that matches the specified permission.
[-type <text>]
- Type of the parameter-
If this parameter is specified, the command displays information about the paramter or parameters of all the templates that matches the specified type.
[-description <text>]
- Parameter description-
If this parameter is specified, the command displays information about the parameter or parameters of all the templates that matches the specified description.
[-recommended-value <text>]
- Recommended value of the parameter-
If this parameter is specified, the command displays information about the parameter or parameters of all the templates that matches the specified recommended value.
[-default-value <text>]
- Default value of the parameter-
If this parameter is specified, the command displays information about the parameter or parameters of all the templates that matches the specified default value.
[-readonly {yes|no}]
- Read-only parameter-
If this parameter is specified with a value of true, then all the parameters that cannot modified of all templates are displayed. If the value specified is false, then all the parameters that can be modified of all templates are displayed.
[-max-length <integer>]
- Maximum length-
If this parameter is specified, the command displays information about the parameter or parameters of all the templates that matches the specified maxium length.
[-range-max <integer>]
- Maximum range-
If this parameter is specified, the command displays information about the parameter or parameters of all the templates that matches the specified maximum range.
[-range-min <integer>]
- Minumum range-
If this parameter is specified, the command displays information about the parameter or parameters of all the templates that matches the specified minimum range.
[-allowed-vals <text>]
- Allowed values-
If this parameter is specified, the command displays information about the parameter or parameters of all the templates that matches the specified allowed values.
The following example displays information about all the parameters of all the templates in the cluster:
cluster1::> template parameter show Template: template1 Permission: readonly Default Read Parameter Type Value Only Description ------------------- ------------ ------------ ---- ---------------------- parameter1 string - No Parameter1 parameter2 IPAddress - No Parameter2
