lun move-in-volume
Move a LUN within a volume
This command moves a LUN to a new path in the same volume or renames a LUN. If you are organizing LUNs in a qtree, the command moves a LUN from one qtree to another. You can perform a LUN move while the LUN is online and serving data. The process is non-disruptive. Use the lun move start command to move a LUN to a different volume within the same Vserver.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-path <path>
- LUN Path -
Specifies the path of the LUN you want to move. Examples of correct LUN paths are
/vol/vol1/lun1
and/vol/vol1/qtree1/lun1
-volume <volume name>
- Volume Name -
Specifies the volume of the LUN you want to move.
[-qtree <qtree name>]
- Qtree Name-
Specifies the qtree of the LUN you want to move.
-lun <text>
- LUN Name }-
Specifies the name of the LUN that you want to move.
-new-path <path>
- New LUN Path -
Specifies the new path of the LUN. Examples of correct LUN paths are
/vol/vol1/lun1
[-new-qtree <qtree name>]
- New Qtree Name -
Specifies the new qtree name that you want to move the LUN to.
-new-lun <text>
- New LUN Name }-
Specifies the new name of the LUN.
cluster1::> lun move-in-volume -vserver vs1 -volume vol1 -lun lun1 -new-lun newlun1
Renames lun1
to newlun1
on Vserver vs1
and volume vol1
cluster1::> lun show -vserver vs1 -volume vol1 server Path State Mapped Type Size -------- ------------------------------- ------- -------- -------- -------- s1 /vol/vol1/A/lun1 online mapped linux 10MB luster1::> lun move-in-volume -vserver vs1 -path /vol/vol1/A/lun1 -new-path /vol/vol1/B/lun1 luster1::> lun show -vserver vs1 -volume vol1 server Path State Mapped Type Size -------- ------------------------------- ------- -------- -------- -------- s1 /vol/vol1/B/lun1 online mapped linux 10MB
Moves LUN lun1
from qtree A
to qtree B
on volume vol1
