lun move-in-volume
Move a LUN within a volume
This command moves a LUN to a new path in the same volume or renames a LUN. If you are organizing LUNs in a qtree, the command moves a LUN from one qtree to another. You can perform a LUN move while the LUN is online and serving data. The process is non-disruptive. Use the lun move start command to move a LUN to a different volume within the same Vserver.
- -vserver <Vserver Name>- Vserver Name
Specifies the Vserver.
- { -path <path>- LUN Path
Specifies the path of the LUN you want to move. Examples of correct LUN paths are /vol/vol1/lun1and/vol/vol1/qtree1/lun1.
- | -volume <volume name>- Volume Name
Specifies the volume of the LUN you want to move.
- [-qtree <qtree name>]- Qtree Name
Specifies the qtree of the LUN you want to move.
- -lun <text>- LUN Name }
Specifies the name of the LUN that you want to move.
- { -new-path <path>- New LUN Path
Specifies the new path of the LUN. Examples of correct LUN paths are /vol/vol1/lun1and/vol/vol1/qtree1/lun1.
- | [-new-qtree <qtree name>]- New Qtree Name
Specifies the new qtree name that you want to move the LUN to.
- -new-lun <text>- New LUN Name }
Specifies the new name of the LUN.
cluster1::> lun move-in-volume -vserver vs1 -volume vol1 -lun lun1 -new-lun newlun1
Renames lun1 to newlun1 on Vserver vs1 and volume vol1 .
cluster1::> lun show -vserver vs1 -volume vol1 server Path State Mapped Type Size -------- ------------------------------- ------- -------- -------- -------- s1 /vol/vol1/A/lun1 online mapped linux 10MB luster1::> lun move-in-volume -vserver vs1 -path /vol/vol1/A/lun1 -new-path /vol/vol1/B/lun1 luster1::> lun show -vserver vs1 -volume vol1 server Path State Mapped Type Size -------- ------------------------------- ------- -------- -------- -------- s1 /vol/vol1/B/lun1 online mapped linux 10MB
Moves LUN lun1 from qtree A to qtree B on volume vol1 .
 PDFs
PDFs
