The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system configuration backup settings clear-password
PDF of this doc site
Creating your file...
Your file is ready
Clear password for destination URL
The `system configuration backup settings clear-password ` command clears the password used for uploads of configuration backups. Enter the command without parameters.
Use the system configuration backup settings show command to display the destination URL for configuration backups. Use the system configuration backup settings modify command to change the destination URL and remote username for configuration backups.
The following example shows successful execution of this command.
cluster1::*> system configuration backup settings clear-password Do you want to clear the password? {y|n}:
