statistics disk show
Disk throughput and latency metrics
This command continuously displays performance data for disks at a regular interval. The command output displays data in the following columns:
Disk - disk name.
Node - node name.
Busy (%) - percentage of time there was at least one outstanding request to the disk.
Total Ops - total operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
[-disk <text>]
- Disk (privilege: advanced)-
Selects the disk for which you want to display performance data.
[-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects the node for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By (privilege: advanced)-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval (privilege: advanced)-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations (privilege: advanced)-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances (privilege: advanced)-
Specifies the maximum number of disks to display. The default setting is 25.
The following example displays disk statistics:
cluster1::> statistics disk show cluster1 : 12/31/1969 16:00:04 Busy *Total Read Write Disk Node (%) Ops Ops Ops -------- -------- ---- ------ ---- ----- VMw-1.31 node2 0 2 2 0 VMw-1.30 node2 0 3 0 3 VMw-1.3 node1 0 0 0 0 VMw-1.29 node2 0 1 0 1 [...]
