vserver consistency-group show
Display a list of existing consistency groups
The command displays information for consistency groups. Use the ` instance ` parameter to display additional consistency group details.
[-fields <fieldname>,…] -
This specifies the fields that need to be displayed.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Selects information about the consistency groups in the specified Vserver.
[-consistency-group <text>]- Consistency Group Name-
Selects information about the specified consistency group.
[-parent-consistency-group <text>]- Parent Consistency Group Name-
Selects information about the specified parent consistency group.
[-qos-policy <text>]- QoS Policy Group-
Selects information about the consistency groups that have the specified QoS policy.
[-tiering-policy <Tiering Policy>]- Tiering Policy-
Selects information about the consistency groups that have the specified tiering policy.
[-snapshot-policy <snapshot policy>]- Snapshot Copy Policy-
Selects information about the consistency groups that have the specified snapshot policy.
[-application-type <Application type for the parent or top level CG>]- Application Type-
Selects information about the consistency groups that have the specified application type.
[-application-component-type <Application component type for child CG>]- Application Component Type-
Selects information about the consistency groups that have the specified application component type.
[-size {<integer>[KB|MB|GB|TB|PB]}]- Provisioned Size-
Selects information about the consistency groups that have the specified size.
[-state {online|creating|deleting|modifying|restoring}]- State-
Selects information about the consistency groups that have the specified state.
[-uuid <UUID>]- Consistency Group UUID-
Selects information about the consistency group that mathches the specified consistency group UUID.
[-create-time <Date>]- Creation Time-
Selects information about the consistency groups that have the specified creation time.
[-space-available {<integer>[KB|MB|GB|TB|PB]}]- Available Space-
Selects information about the consistency groups that have the specified available space.
[-space-used {<integer>[KB|MB|GB|TB|PB]}]- Space Used-
Selects information about the consistency groups that have the specified used space.
[-replicated {true|false}]- Is Replicated-
Selects information about the consistency groups that have the specified replicated status.
[-replication-policy <text>]- Replication Policy Name-
Selects information about the consistency groups that have the specified replication policy.
[-replication-source {true|false}]- Is Replication Source-
Selects information about the consistency groups that have the specified replication source.
The following command lists all the consistency groups on Vserver vs0.
vserver consistency-group show -vserver vs0
(vserver consistency-group show)
Parent
Consistency Consistency
Vserver Group Group State Size Available Used
svm1 cg1 - online 315.8MB 299.1MB 908KB
svm1 cg2 - online 105.3MB 99.72MB 288KB
svm1 cg3 cg1 online 315.8MB 299.1MB 908KB
3 entries were displayed.
The following command shows the statistics for consistency group cg1 on Vserver vs0.
SimpleClus::*> consistency-group show -vserver vs0 -consistency-group cg1 -statistic
Parent
Vserver Group Group
svm1 cg1 -
Last calculated statistic Value
timestamp-metric 11/13/2023 21:11:00
duration PT15S
status-metric ok
available-space-metric 156946432
used-space-metric 344064
size-metric 165568512
iops-other-metric 0
iops-read-metric 0
iops-write-metric 0
iops-total-metric 0
latency-other-metric 0
latency-read-metric 0
latency-write-metric 0
latency-total-metric 0
throughput-other-metric -
throughput-read-metric 0
throughput-write-metric 0
throughput-total-metric 0
Raw statistics Value
timestamp-raw 11/13/2023 21:11:02
status-raw ok
available-space-raw 156946432
used-space-raw 344064
size-raw 165568512
iops-other-raw 0
iops-read-raw 0
iops-write-raw 0
iops-total-raw 0
latency-other-raw 0
latency-read-raw 0
latency-write-raw 0
latency-total-raw 0
throughput-other-raw -
throughput-read-raw 0
throughput-write-raw 0
throughput-total-raw 0
